I’ve bought all my Arduino gear from Core Electronics, but have been assembling a weather station by Cactus.io, see here:
Arduino Weather Station Project - Overview (cactus.io)
My attraction to this project was because it worked with the RG11 Rain Sensor.
The project uses two sensors capable of sensing temperature, the DS18B20 and the BME280; but the temperature reading of the BME280 is ignored in favor of that of the DS18B20. I can monitor the readings of the weather station using either a USB connection to the local computer or an Ethernet connection from any computer on my home LAN. When I do this, I get the same result from the DS18B20: It reads the temperature correctly from the DS18B20 for a while, and then the reading drops to zero. If I power down the Arduino board for a while and then restart it, the DS18B20 again reads correctly for a while and then drops to zero.
So I am trying to figure out what is wrong. Is the DS18B20 faulty and should I order another? Is the Arduino board faulty? Is my Sketch faulty? I have certainly put in a pull-up resistor of 4.7k ohms between the 5 volt supply of the Arduino board and the 1 wire signal line to D9. And when the DS18B20 works at first it gives a very accurate reading.
As for the Sketch, I copied it from the web page of the project and I copy it below. Everything else seems to work fine. So I hope someone can give me some pointers. (Oh, there is an artifact in the readings where some numbers are preceded by an “A” with a squiggly line on top.)
Greg
#include <SPI.h>
#include <Ethernet.h>
#include "TimerOne.h"
#include <math.h>
#include "cactus_io_DS18B20.h"
#include "cactus_io_BME280_I2C.h"
#define Bucket_Size 0.01 // bucket size to trigger tip count
#define RG11_Pin 3 // digital pin RG11 connected to
#define TX_Pin 8 // used to indicate web data tx
#define DS18B20_Pin 9 // DS18B20 Signal pin on digital 9
#define WindSensor_Pin (2) // digital pin for wind speed sensor
#define WindVane_Pin (A2) // analog pin for wind direction sensor
#define VaneOffset 0 // define the offset for caclulating wind direction
volatile unsigned long tipCount; // rain bucket tip counter used in interrupt routine
volatile unsigned long contactTime; // timer to manage any rain contact bounce in interrupt routine
volatile unsigned int timerCount; // used to count ticks for 2.5sec timer count
volatile unsigned long rotations; // cup rotation counter for wind speed calcs
volatile unsigned long contactBounceTime; // timer to avoid contact bounce in wind speed sensor
long lastTipcount; // keep track of bucket tips
float totalRainfall; // total amount of rainfall detected
volatile float windSpeed;
int vaneValue; // raw analog value from wind vane
int vaneDirection; // translated 0 - 360 wind direction
int calDirection; // calibrated direction after offset applied
int lastDirValue; // last recorded direction value
float minTemp; // keep track of minimum recorded temp
float maxTemp; // keep track of maximum recorded temp
// Create DS18B20, BME280 object
DS18B20 ds(DS18B20_Pin); // on digital pin 9
BME280_I2C bme; // I2C using address 0x77
// Here we setup the web server. We are using a static ip address and a mac address
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 45);
EthernetServer server(80); // create a server listing on 192.168.1.45 port 80
void setup() {
// setup rain sensor values
lastTipcount = 0;
tipCount = 0;
totalRainfall = 0;
// setup anemometer values
lastDirValue = 0;
rotations = 0;
// setup timer values
timerCount = 0;
ds.readSensor();
minTemp = ds.getTemperature_C();
maxTemp = ds.getTemperature_C();
// disable the SD card by switching pin 4 High
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
// start the Ethernet connection and server
Ethernet.begin(mac, ip);
server.begin();
if (!bme.begin()) {
// Serial.println("Could not find BME280 sensor, check wiring!");
while (1);
pinMode(TX_Pin, OUTPUT);
pinMode(RG11_Pin, INPUT);
pinMode(WindSensor_Pin, INPUT);
attachInterrupt(digitalPinToInterrupt(RG11_Pin), isr_rg, FALLING);
attachInterrupt(digitalPinToInterrupt(WindSensor_Pin), isr_rotation, FALLING);
// setup the timer for 0.5 second
Timer1.initialize(500000);
Timer1.attachInterrupt(isr_timer);
sei();// Enable Interrupts
void loop() {
ds.readSensor();
bme.readSensor();
// update min and max temp values
if(ds.getTemperature_C() < minTemp) {
if(ds.getTemperature_C() > maxTemp) {
// update rainfall total if required
if(tipCount != lastTipcount) {
cli(); // disable interrupts
lastTipcount = tipCount;
totalRainfall = tipCount * Bucket_Size;
sei(); // enable interrupts
// listen for incoming clients
EthernetClient client = server.available();
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
digitalWrite(TX_Pin,HIGH);
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close"); // connection closed completion of response
client.println("Refresh: 10"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html><body>");
digitalWrite(TX_Pin,HIGH); // Turn the TX LED on
client.print("<span style=\"font-size: 26px\";><br> Temperature is ");
client.print(ds.getTemperature_C());
client.println(" °C<br>");
client.print("%<br> Humidity is ");
client.print(bme.getHumidity());
client.println(" %<br>");
client.print("%<br> Pressure is ");
client.print(bme.getPressure_MB());
client.println(" mb%<br>");
client.print("%<br> Wind Speed is ");
client.print(windSpeed);
client.println(" mph<br>");
getWindDirection();
client.print("%<br> Direction is ");
client.print(calDirection);
client.println(" °<br>");
client.print("%<br> Rainfall is ");
client.print(totalRainfall);
client.println(" mm<br>");
client.print("%<br> Minimum Temp ");
client.print(minTemp);
client.print("%<br> Maximum Temp ");
client.print(maxTemp);
client.println(" °C</span>");
client.println("</body></html>");
digitalWrite(TX_Pin,LOW); // Turn the TX LED off
break;
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
// Interrupt handler routine for timer interrupt
void isr_timer() {
timerCount++;
if(timerCount == 5) {
// convert to mp/h using the formula V=P(2.25/T)
// V = P(2.25/2.5) = P * 0.9
windSpeed = rotations * 0.9;
rotations = 0;
timerCount = 0;
// Interrupt handler routine that is triggered when the rg-11 detects rain
void isr_rg() {
if((millis() - contactTime) > 15 ) { // debounce of sensor signal
tipCount++;
contactTime = millis();
// Interrupt handler routine to increment the rotation count for wind speed
void isr_rotation() {
if((millis() - contactBounceTime) > 15 ) { // debounce the switch contact
rotations++;
contactBounceTime = millis();
// Get Wind Direction
void getWindDirection() {
vaneValue = analogRead(WindVane_Pin);
vaneDirection = map(vaneValue, 0, 1023, 0, 360);
calDirection = vaneDirection + VaneOffset;
if(calDirection > 360)
calDirection = calDirection - 360;
