Hi Core.
I’m after a mono E Ink display ~6" or bigger that I can drive from a Pi or Pico, Python or MicroPython.
Unframed so I can fit it to a frame I’ll make.
The project is a weather station display. The WS itself is currently Pico.
Please recommend a product.
Cheers.
Mark
Hey there, @Mark285907,
The Waveshare 5.79inch e-Paper display Module, e-ink display, 792x272, Black/White, SPI Interface (SKU: WS-26892) is my bet. Its a nice sturdy screen, can easily work with the Pico, and you can mount it directly into the photo frame.
Its one of several epaper displays I have at home.
Thanks Jane.
That’d work but I was thinking of something more along the lines of 6:4 ratio.
Something like Simple e-ink dashboard - Tutorial Australia but the product link doesn’t work.
Cheers.
You could do something like the Waveshare 7.3inch 6-Color E-Paper Display HAT. It’s 800×480, so much closer to the dashboard layout than the very wide.
It’s not monochrome and I will warn you that if you’re after fast refresh time, it’s probably not the best idea unless you only need an update every 10mins or longer. It works great as a photo frame (mine at home updates every hour) but maybe not as good as a weather station.
If you go smaller, you have a few more options like the 4.2 inch 3-Colour E-Ink display module (400x300 Pixels) (SKU: WS-13454). Pimironi have a similar option: [Pimoroni Yellow/Black/White – Inky wHAT (ePaper/eInk/EPD) (SKU: PIM433)](Pimoroni Yellow/Black/White – Inky wHAT (ePaper/eInk/EPD) (SKU: PIM433)), which is the one I use at home.
But yeah, that 6inch 2:3 ratio is a little hard with the eink screens.
Thanks Jane.
Yes, I saw some comments and descriptions for the larger screens marketed specifically as photo frames and wondered what the issue was. Refresh times would be an issue.
I suppose there’s no reason I can’t use two WS-26892 on the one SPI bus, in the one frame with a centre spline covering the edges.
That said, 20s+ refresh on the 7.3inch 6-Color E-Paper Display, E-Ink Display HAT | Buy in Australia | WS-27875 | Core Electronics would be no drama. Its a weather station so 5 minutes + would be fine.
For the largest largest display area two monochrome 7.5" panels side-by-side. This gives you something roughly equivalent to a 15" weather dashboard, which starts to look like a commercial information display.
