Hi.
Hoping someone can point me in the right direction.
I just received a new FireBeetle Board ESP32-E DFR0654 and I would like to use it with WLED.
I have successfully installed the software and am about to start wiring it up to the LED strip but noticed that there is no “pin4” that is normally used for the data/signal channel for the LED’s.
The board does however have the following options and I was not sure which one to use:
A4
D4
SDA
Can you please let me know as I do not want to fry the board.
Just a quick typo correction from my initial post. There is no D4 pin. All the options available are:
RST
3V3
GND
EN
SCK
MO
MI
SCL
SDA
D7
D6
D5
D3
D2
TX
RX
I have connected the:
GND wire of the LED strip to the GND connection on the ESP
5v wire on the LED strip to the VCC connection on the ESP
Now just wondering where to connect the data/signal wire on the LED to on the ESP.
