Hi, I am using the SIM7600G-H 4G HAT by Waveshare to control an RPI with reverse ssh.
I want my system to be robust to hung-ups, and as such, a reset to the entire RPI with an SMS would be awesome. Can the modem be used for a Hardware reset for when the RPI is stuck?
One of our forum users @Dave65452 has put together a GitHub repo for executing shell commands with a text message over in this post that should get you pointed in the right direction.
Looking at the hat there doesn’t appear to be any way you could interface with the reset pins directly.
From my experience with running a Pi as a router, the Pi itself is rarely the issue (Currently have 4 months+ of uptime on my Pi router without the need of a reset)
If you’re using the hat to get an internet connection, you could look at having the Pi run an access point with a microcontroller that has wifi capabilities that then attempts to ping say 8.8.8.8 and if it doesn’t receive a response to short the run and ground pins on the Pi
