As the tittle suggests could someone suggest how to fix this monstrosity
So I have a rpi4 in pibow case with fan shim. On top of that I want to put my mini pitft screen. I need to use a stacking header to put some space between the fan and screen… but as you can see it’s a little too much space.
Can anyone suggest a solution? I’ve heard cutting the pins isn’t an option?
