You’re dead right there, the 4000mAh would be the biggest you could fit and keep the original 6mm thickness. considering the current battery is swollen to 15, I’d see if you can find something small enough with the right thickness and put it in the battery compartment, and see if you can close it. Perhaps you’ll come out of this with more battery capacity!
All the best with the replacement process, let me know if you want something clarified!
