How to install picamera into raspberry pi 4 model B
Hi Phitak,
Depending on which OS you are using it is slightly different. For Bullseye and later the current library is Picamera2.
You can test if this is installed by running this in the terminal.
rpicam-hello
If that doesn’t work you may need to install the library. The documentation outlines how to set this up under the getting started section.
