Hi Brent
Just put Element 14 or RS Components in your browser and navigate to connectors. You should be able to do some filtering and if there are any numbers on the connector this would help.
I don’t think this is an option you want to get involved with. Reading between the lines your experience with this sort of thing seems to be about Zero. I have been around for many years and I would certainly stop short of crimping pins on wires to fit another connector up under a vehicle dash. I don’t believe you would have the tooling to do this anyway or the expertise to use it.
I think that by the time you mucked about with all these ideas it will be more economical, quicker and easier to just go out and purchase the correct harness. Believe me a decent crimp tool will cost you more than the harness, There are some on E-Bay but they all seem to come from USA. There is one user found by selecting “Australia only” but his shipping time quotes 1st May earliest which sounds suspiciously like the item is off shore somewhere.
