Hi there, question please.
I am looking to run up to 20 step motors at the same time (with different stepper target for each).
I understand that the Arduino mega 2560 R3 can run up to 8 motors only?
Stepper target definition would run via Rhino/Grasshopper.
JC
Hi Joachim,
You will need a stepper motor driver to use a stepper motor with Arduino. You can run 3 or 4 Stepper motors with an Arduino Mega and as many stepper motor drivers:
https://core-electronics.com.au/tb6600-stepper-motor-driver.html
You can drive even more stepper motors with one of these to gain more PWM outputs:
https://core-electronics.com.au/adafruit-24-channel-12-bit-pwm-led-driver-spi-interface-tlc5947.html
I’m not sure how you would interface with Rhino though
Hi Stephen, thank you - much appreciated!
Will have a closer look at the PWM driver.
JC
Talk about a week late: Adafruit have just released a motor driver HAT for the Pi zero. Might be worth considering for your next project.
Core will probably stock in due course, but here’s a link anyway.
https://www.adafruit.com/product/4280Aa
