Core Electronics Forum
Lulzbot Mini Bed y-axis homing error
Hi, when i press home in Cura the bed moves to the front of the machine, but has become uncalibrated and is trying to move past the y-endstop, which results in a loud clashing noise as the motors and belt keep trying to move the bed past the physical limits of the assembly. It has been doing this every time I try to home the device, and I don’t know how to reset the y-axis home settings so it doesn’t keep trying to force the bed past the front of the machine. any help is appreciated.
Hey, could you check under the print bed and make sure all the wiring connectors are still intact? I have seen this before and one of the smaller wires attached to the endstop switch had come loose.
Ok I’ll do that. Thanks!
