Core Electronics Forum
Lulzbot Mini printing Ripples
#1
I purchased a Lulzbot Mini a couple of weeks ago. Since then I’ve printed enough pieces to go through a 1kg reel of ABS.
I printed a fairly large piece last night and I noticed that there are ripples being generated in the outer layer. I presume this is something to do with the head “bouncing” when going round tight corners.
Is there something I need to do to the printer to dial these ripples out? Has the printer loosened up now so I need to tension belts or something like that? Or is it simply a case of lowering the speed/acceleration values?
Any help would be appreciated.
Dan
#2
Hey Daniel,
To see if we can half split the issue, could you try slowing down your prints and seeing if the problem becomes more noticeable/worse?
In any case, it wouldn’t hurt to do some maintenance on your printer and make sure it’s all up to scratch. Check out this guide for more info.
#3
Ok thanks,
I’ll give that a go and let you know the results.
Dan
#4
Slowing down the print from 40mm/s to 30mm/s hasn’t made any real difference.
I’m going to have another go at tightening the belts tonight because I may not have gotten them tight enough.
I’m also going to slow down just the outer layer by a fair bit more (to 10mm/s) to see what that does.
Dan
#5
@Daniel25998, how did things go?
#6
Tightening the belt on the print head has made a big difference. There is still a little bit of ghosting on flat edges after sharp turns however…
I’m going to have another go at tightening the belt on the print bed because I seemed to have 3 left hands in the last attempt and I don’t think I made any sort of change to the tension.
Not sure that changing the print speed has made any noticeable difference… I will need to do some back-to back runs with difference speed settings to really try and understand how it also affects the problem…
Dan
#7
Definitely think belt tension is the key to this. Getting the belts tight has made the most difference.
Having said that, I’m also printing now at top/bottom 20mm/s and Outer/Inner 15mm/s and I’m getting good quality now. The ghosting is still there but you have to look very hard to see it.
Dan
#8
Glad to hear it Dan. Aidan will be in later tomorrow and may have some further ideas on optimising that quality for you.
