This is a placeholder topic for “Micro servo - SG92R” comments.
Tiny little servo can rotate approximately 180 degrees (90 in each direction), and works just like the standard kinds you’re used to but smaller. You can use any … read more
How can i connect this to breadboard? is there any adapter for it?
For a soldered breadboard, user header pins:
For solderless breadboards the headers will also work, or you can just use male-to-male connectors:
Thanks for your reply, i will go with second option.
