MQTT publishing Laird Sentrius RG191 LoRaWAN Gateway (AU Version)
Can you confirm that the Laird Sentrius RG191 LoRaWAN Gateway (AU Version) supports MQTT publishing?
Hi Brian,
Welcome to the forum!!
In short any gateway only provides a connection for LoRaWAN nodes to the TTS network. MQTT has to be access through another means, usually a webhook.
Though outdated this guide walks through the general hardware/software stack - and shows the information flowing from node to your dashboard/MQTT broker (Adafruit.io)
The Things Network, IFTTT, and BEYOND! - Tutorial Australia
If you are looking for a more local connection you could create your own Peer-Peer Lora network (with an MQTT integration)
