Hi all.
Im just a beginner with Arduino.
Verifying is ok but when i go to upload the below error keeps coming up.
Can anyone help please?
/usr/local/bin/arduino-cli compile --fqbn arduino:megaavr:nona4809:mode=on --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/805509177/build --build-path /tmp/arduino-build-F159BC4C1AB5974E1E3F9C885779A717 /tmp/805509177/POLICE_strobe
Sketch uses 2014 bytes (4%) of program storage space. Maximum is 49152 bytes.
Global variables use 22 bytes (0%) of dynamic memory, leaving 6122 bytes for local variables. Maximum is 6144 bytes.
Upload started
Programming with: Serial
Restarting in bootloader mode
Flashing with command:C:/Users/murph/.arduino-create/arduino/avrdude/6.3.0-arduino17/bin/avrdude.exe -CC:/Users/murph/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega4809 -cjtag2updi -PCOM3 -b115200 -e -D -Uflash:w:C:/Users/murph/AppData/Local/Temp/arduino-create-agent229494642/POLICE_strobe.hex:i -Ufuse2:w:0x01:m -Ufuse5:w:0xC9:m -Ufuse8:w:0x00:m {upload.extra_files}
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/Users/murph/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : jtag2updi
Overriding Baud Rate : 115200
avrdude: jtagmkII_getsync(): sign-on command: status -1
avrdude: ser_recv(): read error: The I/O operation has been aborted because of either a thread exit or an application request.
avrdude: ser_send(): write error: sorry no info avail
avrdude: jtagmkII_send(): failed to send command to serial port
avrdude: ser_recv(): read error: Access is denied.
avrdude: jtagmkII_getsync(): timeout/error communicating with programmer (status -1)
avrdude done. Thank you.
