I have a Pi zero camera kit and I. want. tto. use it as a reverse camera for my wheelchair was wondering if I could connect a screen and have the lines AND reverse beeper for me getting. within 20cm to something?
Whilst you can absolutely hook up a display (I’d recommend a small HDMI screen - HDMI is designed for longer distances like one end of a wheelchair to another), distance will be a bit harder. You could absolutely hook up a small speaker to that screen via the 3.5mm port, and sense distance with something like our PiicoDev Laser Distance sensor:
Either way, it’ll need a bit of coding nouse
Let me know if this sparks any followup questions!
Hi James
sounds perfect could it all run off one power supply?
could those speaker’s play music and could I hook up a larger speaker to hook up a lip reading pi to speak for me lol sorry this is how my brain works
thankyou so much
Shane
it is all going. on my. wheelchair if I get a cable put at the back to run it all. what would you recomend leaving room for upgrades?
OI could run a spare 12v battery?
