Python code for position control of DC motor with encoder
I’m looking to automate the opening and closing a door weighing about 3Kg. I have tried using a 25Kg.cm servo but find that slowing the servo by moving in increments results in a jerky motor response. It seems that a 1:500 geared DC motor with an encoder might be more suitable. I have not been able to find suitable python code to control the position of such a motor.
Can somebody please refer me to some python code that could be adapted to rotate motor with encoder say 100 degrees when a signal is sent to a RPi pin, and then reverse when receiving another signal?
Thanks, Richard
Thanks Mark, I’ll try adapting your code which is out of my league.
Hi Richard,
To get your servo working you might be able to use a bendy or stretchy linkage to smooth it out a little or add a reduction either through changing the length of the linking arm or a gear system.
Mark has some great code there and if you need a hand adapting it I’d try some AI tools or post back here and we can take a look!
Thanks Liam for these ideas. I’ll try these and let you know if I get an acceptable result.
Richard
