I am connected to my university internet via ethernet cable that is provided in my room. So, I do not have physical access to the university LAN router and yes, they (IT Support) do not offer any help if you are using Linux. Whenever I plug the ethernet cable to my windows laptop, internet browser appears automatically, showing the university portal page and once I log in (using username and password provided), I get access to the internet. I have observed that on the windows laptop if I do ipconfig/all, the following information appear same all the time and IP address does not change. The following is the ipconfig/all output of my windows laptop connected to internet via ethernet cable.
My Problem
I have got a new raspberry pi 3 (running latest Raspbian Stretch with Desktop - June 2018) from Core Electronics and at first, I was unable to connect it to the internet at all. Searching forums all over the internet for 2 days, I managed to get a WiFi connection on it by modifying the wpa_supplicant.conf file as shown below,
Ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
Update_config=1
Country=AU
Network={
ssid=”ABC University”
scan_ssid=1
key_mgmt=WPA-EAP
group=CCMP TKIP
eap=PEAP
identity="student id"
password="student portal password"
phase1="peapver=0"
phase2="MSCHAPV2"
However, I need to connect internet via ethernet cable because I am running a camera with my Raspberry Pi and I want to get live stream remotely. I am aware that I need port forwarding and the university offered me port forwarding on the above stated IP address for a period of 1 month. Unfortunately, I need to connect to the internet by myself and I do not know how to achieve this. I hope to get help through this forum to get it working. I am ready to provide extra information if required. Thanks in anticipation.
Regards,
Sahar
