I just got a Raspberry Pi 4 2GB from Core electronics, and no matter what I do, I do not at any stage get a green light, I have the red power light (it is powered by a 2.4 amp power supply, and I follow guides to the letter and nothing. I have even tried re loading the bootloader etc but still only a red led.
Can anyone help or is it faulty and need to be exchanged?
If you believe your part is faulty please send through an email to support@coreelectronics.com.au and a member of the support team will be able to lead you through the process required for your part. As for some advice in troubleshooting can I please confirm the OS that has been flashed to the SD card in the Pi? Also what’s the capacity of the card that’s being used?
You Will Need To Use The Rasbarry Pi Official Power Supply
All so Note The 2gb Version of The Pi 4 Mother Bord has 2 versions 1.1 and 1.2 the 1.1 usb-c has issies so go with the 1.2 version if you are unchure what version bord you have ie Rasbarry Pi 4 Model B Check there Bord it should State Someing Like Rev V1.1 or Rev V1.2
