Hi team, I am looking to purchase two raspberry pi hats from your site to hopefully stack. The two are
Waveshare SIM7600G-H 4G HAT SKU: CE07826 and PiJuice Hat SKU: CE05650
Would you be able to assist to see if they can work together stacked on a Pi? Will they also both fit into the HiHat case?
Electrically those ones should work - the PiJuice only uses the I2C pins on the Pi: PiJuice at Raspberry Pi GPIO Pinout
And the 4G HAT uses a range of them but not the same pins
Unfortunately both HATs arent able to fit inside the HighPi case, and the 4G HAT alone was a tight fit, the USB-UART port and PWRKEY buttons were cut off. With some modification and knocking out the two side panels will let you connect USB, the antennas and the audio port (provided the cable is small enough).
Let us know if you have any other questions!
Liam.
