Raspberry Pi NoIR Camera Board v2 - 8 Megapixels (CE04422)
This is a placeholder topic for “Raspberry Pi NoIR Camera Board v2 - 8 Megapixels” comments.
If you thought the standard Raspberry Pi Camera Module was great, then you’ll love the NoIR. It features an 8 megapixel Sony IMX219 sensor and a supporting PCB designed with the Raspberry Pi in mind.
whats the difference between this NOIR and the other V2 camera?
NoIR is short for No InfraRed filter. It’s a version 2 camera module. You can use this as a normal camera but your colours will be a bit odd because the carera is picking up infrared light not normally visible.
They’re used for low light and IR photography. You can use infrared LEDs to light up a scene at night but you cant see it. The use these in security cameras for night vision.
Ah OK, thanks for the info. I have a V1 camera. Will get the non-NOIR then. :slight_smile:
