Rd-03D mmWave Multi-Human Position Sensor (CE10172)
This is a placeholder topic for “Rd-03D mmWave Multi-Human Position Sensor” comments.
Track people’s position in smart home or robotics projects with this handy module!
For Rd-03D. I am looking to house this outside. Firstly, do you have containers suitable? Can the waves go through glass or does it nothing in front of sensors? Thanks
Do you have any housing for the Rd-03D that is suitable outside?
Hi @Paul297164,
Welcome to the forum!
The Rd-03D mmWave Multi-Human Position Sensor | Buy in Australia | CE10172 | Core Electronics will be able to penetrate anything that isn’t conductive so glass will be no issue.
For an outdoor housing we stock Plastic Project Box Enclosure Waterproof Clear Cover - 168 x 120 x 55 mm | Buy in Australia | FIT0723 | DFRobot | Core Electronics that will be able to have the signal penerate the cover as well as keeping it dry.
Is this Rd-03D the same as HLK-LD2450 ?
If so, it is supported by Home Assistant via ESPHome
If not, you might like to see if there is any information on connecting, programming and using it - because the linked datasheet looked to be all about the hardware specs.
Hey @Donald23173,
I had a look at the LD2450, and it looks pretty darn similar. From the board layout, to how it operates. I had a brief look at the UART output format and from what I can remeber, it appears to be the same or very similar.
I guess that it could be a drop-in replacement, but it would need to be tested so I can’t say with 100% certainty. The deep dive into the UART format is not in our write-up, but you can find some in this guide.
If you do get it to work, let us know! Curious if it will!
As Jaryd says, it looks pretty much identical. I use ESPHome firmware generator, and I found comments in the ESPHome forum (dated Jan-2024)
Which suggests that the same firmware might work for either board.
Today I see that there are ESPHome components for both LD2450 and RD-03D. Both return position details for up to 3 targets.
However the ESPHome LD2450 component has a lot more controls - adding 3 zones. Honestly configuration looks so much more complicated - but we don’t have to configure all the options that we don’t need.
RD-03D LD2450
Binary sensor for has-target Binary sensor for has-target
Binary sensors for has_moving_target and has_still_target Binary sensors for target1, target2 and target3
for each target_N: integer sensors for x, y, speed, angle, distance, resolution for each target_N: sensors for x, y, speed, angle, distance, resolution
for each zone_N: target_count, still_target_count, moving_target_count
Switches for: bluetooth and multi_target
Integer number for: presence_timeout and for each zone: x1, y1, x2 and x2
Button for: factory_reset and restart
Text sensors for: version, mac_address, and for each target: direction
Select for: baud-rate and zone_type
I have 3 nightlight type uses, so I might try both the AiThinker RD-03D and HLKtech LD2450 (including RD03D with the LD2450 component). Worst case is that the bedroom unit only needs to see feet moving from under the bed :wink:
Don’t hold your breath though … I am an A-grade procrastinator so it could take quite a while before ready to announce my results.
I haven’t tried the RD-03D yet, but I was impressed with all the positional information available from the LD2450’s ESPHome component - great to track 3 persons within the range … but overkill for my simple night-light application.
Comparing all the many LD24xx models, I’m thinking LD2410C might be best for a simple night-light. I already bought a LD2410B - whose specs seemed ideal until I saw how tiny it is. Small will be good for a night-light … except that I don’t trust my soldering for attaching such close small pins.
