I have purchased the above display for my rasp pi 3B+ which is in a Pibow ninja coupe case. Is there a frame or bezel which will enable the pi to be attached mechanically to the display?
Thanks in advance.
K
Hi Kevin!
The Seeed studio 7 inch display is a pretty bare bones unit, as far as I know there isn’t a frame or case that will allow you to mechanically attach your Pi to it. I think your best option might be to create your own Pibow style stacked acrylic case.
Good luck with your project! Let us know if you work something out!
Or you could 3D print one
