Seeeduino Nano (Seeed Studio) (SS102010268)
This is a placeholder topic for “Seeeduino Nano (Seeed Studio)” comments.
The Seeeduino Nano is a compact board similar to the Seeeduino V4.2/Arduino UNO, and it is fully compatible with Arduino Nano on pinout and sizes. Compare to Arduino Nano, Seeeduino Nano use Type-C instead of Mini-USB, which is symmetrical and reversible.
Could anyone tell me if the Grove connector on a Seeduino Nano is compatable with StemmaQT / Piicodev cables?
Not directly. Grove uses JST PH I believe, while piicodev, stemma qt, and qwiic all use JST SH. Grove does not use PH, it’s something else.
https://wiki.seeedstudio.com/Grove_System/
You’ll need an adapter from Grove I2C, and you’ll also need to check the voltage of your device is 3.3v or use a logic level shifter (unless you’re using a stemma qt device, as these all have level shifters on board). The Seeeduino nano is a 5v device.
Here’s one (just the first that came up in a search, I’m sure there are others):
