Single-Ended Flexible LED Filament - 3V 25mm long - Warm White (ADA6141)
This is a placeholder topic for “Single-Ended Flexible LED Filament - 3V 25mm long - Warm White” comments.
This flexible LED filament is often seen in 'Edison-like' LED bulbs, arranged in different patterns to give a bright warm lighting effect…
where can I find the data sheets or at least the Vf for LEDs I’ve purchased?
Hi @max295196
Welcome to the forum!
I’ve added the datasheet for the LED on the product page, you will be able to access it via this link: Single-Ended Flexible LED Filament - 3V 25mm long - Warm White | Buy in Australia | ADA6141 | Core Electronics
