I’m am rebuilding a FCB1010 into something that is more capable. To do this I am gutting the internals and installing a Teensy 4.1 and Teensy Audio card. I have delusions of it working like a bass pedal, MIDI sequencer and/or drum machine.
In this Video I explain how I modified the inside electronics. You can tell by the soldering and general construction that I am more of a programmer!
That’s excellent! Pretty impressive what the Teensy with an appropriate Audio card is able to do. I’d imagine you’ve seen The Euclidean a project Ken was working on a while back, might be an idea for another project to put together:
Also, I’m working on a little PR for your code at the moment. Just want to grab a Teensy from stock and ensure that my modifications will work correctly before I create a commit for it
Thanks. The code is just for testing, but feel free to make suggestions.
I have seen the project you suggested. I am interested but I have a lot of ideas to go through on the current project…
No worries. Thought I’d make a suggestion to see whether it’s something you can use in the final project to make it shorter. I mainly modified your function readSwitches() to use a for loop iterating over an array rather than checking every single value in an if-statement.
/* Testing Hardware for TEE1010
By John Melki-Wegner (aka Expensive Notes)
// === MIDI ==================================================================== MIDI
#include <MIDI.h>
MIDI_CREATE_INSTANCE(HardwareSerial, Serial7, MIDI);
int channel = 1;
// === Variables =============================================================== Variables
int reading; // the current reading from the input pin
//Pots : Analogue pins
const int potPin[] = {A0, A8, A14, A15, A16, A17}; // Input pins from the potentiometers
int potVals[6]; //input values from pots
const int foot[] = {0, 1, 2, 3, 4, 5, 30, 31, 32, 33, 36, 37, 26, 27, 34}; // Note that the last five positions represent footUp, footDown and the three additional switches respectively
const int additionalSwitch[] = {26, 27, 34};
const char footPrint[][12] = {" foot1 ", " foot2 ", " foot3 ", " foot4 ", " foot5 ", " foot6 ", " foot7 ", " foot8 ", " foot9 ", " foot10 ", " footUp ", " footDown ", " addSwitch1 ", " addSwitch2 ", " addSwitch3 "};
// #define numberSwitches 15 // This appears to be unused, just commenting up
//=== Oled Screen ================================================================ Oled Screen
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET 4 // Reset pin #
#define SCREEN_ADDRESS 0x3C // Found using scanner
//Changed Wire to Wire2 for SCL2 and SDA2 Yay!
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire2, OLED_RESET);
// === MIDI ========================================================================= MIDI
byte stopMIDI = 0xfc; //MIDI stop
byte midi_clock = 0xf8;
int note = 60;
int BPM = 250;//Beats per Minute maximum?
int waitTime = 40; //Time between sending MIDI clock
int spareTime = 40; //Time left after processes are done that needs to be padded/wasted while waiting for mext beat/note
// === Setup ======================================================================== Setup
void setup()
//USB Serial for debugging
Serial.begin(9600);
for (int cFoot : foot) pinMode(cFoot, INPUT_PULLUP); // Sets every pin in foot to
//MIDI Serial in and out
Serial7.begin(31250); //MIDI baud rate
Serial7.write(stopMIDI); // just in case
MIDI.begin(MIDI_CHANNEL_OMNI); // Launch MIDI and listen to channel 1
//--- Screen ------------------------------------------------
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// === Loop ======================================================================== Loop
void loop()
int t1 = millis();
readPots();
readSwitches();
sendMIDInote();
showScreen();
int t2 = millis();
Serial.print("\tTime to Read Switches etc. :\t");
Serial.print(t2 - t1);
Serial.print("\tSpare time:\t");
spareTime = waitTime - (t2 - t1);
Serial.print(spareTime);
Serial.print("\tMIDI in?? ");
while (t2 - t1 < waitTime) {
if (MIDI.read()) {
byte type = MIDI.getType();
Serial.print("\t");
Serial.print(type);
t2 = millis();
Serial7.write(midi_clock);
Serial.print("\t");
Serial.println();
void showScreen() {
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(15, 0);
display.println(BPM);
display.setCursor(15, 20);
display.println(spareTime);
display.display();
void sendMIDInote() {
MIDI.sendNoteOff(note, 100, channel);
note++;
if (note > 65) note = 60;
MIDI.sendNoteOn(note, 100, channel);
void readPots() {
for (int i = 0; i < 6; i++) {
potVals[i] = analogRead(potPin[i]);
Serial.print(potPin[i]);
Serial.print("=");
Serial.print(potVals[i]);
Serial.print(" ");
BPM = map( potVals[0] , 0, 1023, 20, 250);
waitTime = int(60000 / BPM / 6); //Time between MIDI clock out
void readSwitches() {
for (int iter = 0; iter < 16; iter++) if (digitalRead(foot[iter]) == LOW) Serial.print(footPrint[iter]);
Thanks Bryce. I usually do what you have suggested and iterate through arrays. For example, in the real program I will have arrays inside arrays in order to implement key and scale changes. I was just being lazy with this program. Your use of the constant char array was great idea for the names of the pedals. I appreciate your feedback, thanks for taking the time to improve it.
One thing I have very little experience with it GitHub so I am not sure if I have accepted your changes correctly.
Git can be a bit awkward to get started with but their documenation does a good job at keeping things succinct and detailed: Merging a pull request - GitHub Docs
Thanks for your help Liam. I ended up just adding the new version to Github, unfortunately that means Bryce’s work isn’t acknowledged. However, it is appreciated. Next time I will try to use Github properly.
No worries at all!
A quick Google search should get them pointed at this forum topic, though a comment might be a good way to link everything together.
I’m loving the updates by the way, the video explanations are superbly sucinct and give a lot of info!
