I am a total newbie and first time poster. My daughter needs to make a diorma for school and would like to include a dialogu that she will record of approx 1min. Was thinking of using DFRobot DFPlayer PRO - A MP3 Player, with a small speaker, push button to start the dialogue and a battery source. Can anyone please advise all of the components i would need to order?
@Doug27394 has pretty much everything covered well with some top picks there.
Just to add briefly, these units are intended to be connected via the header pins which need to be soldered on. Not having access to a soldering iron makes things a little trickier as just pushing wires into place won’t give a very reliable connection that’s prone to cutting out when it is moved or bumped but it might be ok since the diarama shouldn’t have too many connections.
You can power the unit via the USB-C connector using a mobile phone battery bank, this should be more reliable than pushing wires into the Vin and Gnd holes and taping/blu-tacing them into place.
