2-Pin Female JST XH-Style Cable (15cm) (POLOLU-1164)
This is a placeholder topic for “2-Pin Female JST XH-Style Cable (15cm)” comments.
This 6" (15cm) cable has two 26AWG conductors with a 2.5mm-pitch 2-pin female JST XH-style connector. The spacing is very close to 0.1", which means this connector will work with 0.1" male header pins and standard perfboards and solderless breadboards. The other ends of the wires are unterminated; they can be cut to length to match your application. The red and black wires are twisted together to reduce noise.
Is it possible to get a bunch of the connectors (just the female part) and the crimps? I’m wanting to use colour coded cables in a project and would like for the cables to go from the switch to the board.
This should do the job:
