Hi Bryce,
I’ll order one of these cases from your site if they are available. If the other shows up, I can use both.
Best regards,
David
Hi Bryce,
Best regards,
David
Oliver,
Does this also work with the r.pi 3B+? the 4 is overkill for our product and heat is an issue for us with the 4 as well.
Thanks,
David
Pretty sure the case will only work with a Pi 4.
Checked the case I have on a Pi 3+ the connectors are in different places.
See links below, Ethernet has changed side, HDMI is smaller, 2 micro USB connectors.
Hi All,
James is right - they moved the connectors around on the Pi 4, so in general cases for the Pi 4 are not compatible with cases for the Pi 3, and vice versa.
Regards,
Oliver
Support | Core Electronics
