Hi, does anyone know how I can connect the piicodev sensors to the breadboard directly instead of connecting it to the expansion board?
This is what I use. ![]()
Or maybe one of these
Core have so many options (number of pins, male/female, number of pins/wires, etc) that it can be rather daunting using Core’s Search function. I have found that adding more keywords doesn’t narrow the search, but expands it exponentially ![]()
Those adapter boards and breakout cables mentioned above are definitely the easiest plug-and-play options. If you’re after a more compact or semi-permanent breadboard setup though, most PiicoDev sensors actually have unpopulated header holes along the edge of the board….You can solder standard male header pins there and plug the sensor straight into a brreadboard, just like a typical breakout , no extra cables needed. just a quick heads-up: double-check the pin labels (GND, 3V3, SDA, SCL), as the order can differ from the expansion boards.
