HI All,
Please see attached photos,
I have ensured the screen is clean and plugged in well to the motherboard
However the light does not appear to be coming through the LCD screen
The prints are no longer coming through cured
HI All,
Hi Chris,
I am currently looking into this, in terms of warranty and repairs. But in the meantime could you post a video of what happens when you press the calibrate screen button located in the tools menu of the printer.
Please see attached link with video file
Hi Chris,
The screen should have displayed a rectangle in that video.
If you could check one more thing that would be a big help (I know that you have already done this).
Thanks for your help Chris, if this doesn’t work will make sure we sort this out for you.
Hi Mitchell,
please see attached videos and Pictures taken after your request has been completed
Unfortunately to no avail same issue
No insects inside or dirt / dust wiped down the board and connectors with IPA waited for it to dry then re-plugged all back in
Hi Chris,
Sorry for the delay in getting back to you on this one. We’ve sent through an email with how to send it back so we can get it sorted ASAP. Thanks for all your effort in troubleshooting this one!
Regards,
Oliver
Support | Core Electronics
Hi Chris,
I’ve deleted your post to protect your personal details. It would be best to handle your warranty claim via email rather than on the forum. That way you won’t be posting your personal details in public.
FYI, there’s a collection run from our PO Box twice a week - and yes, definitely, we’ll let you know as soon as it arrives to us here in the support team.
Regards,
Oliver
Hello, may I ask what was the problem? I am facing the same issue now. I measured voltage, checked cables and connections and still the same.
Hi Tom,
I’ve looked into this for you, and found that in this case it was an LCD failure. The LCDs in SLA printers age when exposed to the strong UV light, with the monochrome (002H) LCDs lasting longer than the colour ones (002R). We’ve got a 6 month warranty on our 002Rs so if you bought it from us recently, it’d be covered under warranty, but keep in mind that the LCDs are consumables that can be purchased from our store:
Happy printing!
Hello James, thanks for the answer, you saved my day
And by the way I confirm there was a display issue. After replacing the display everything works fine. Thanks again for help
Hi Tom,
Thanks for getting back to us with confirmation! That should help others when they run into your issue down the line.
Great to see that our advice did the trick
