This is a placeholder topic for “Embedded Serial to Ethernet Module” comments.
WT32-ETH01 is an embedded serial to Ethernet module based on the ESP32 series WT32-S1 MCU. Integrating an optimized TCP/IP protocol stack and supporting…
Read moreThis is a placeholder topic for “Embedded Serial to Ethernet Module” comments.
Read moreSki: DFR0963
Will this power over Poe out of the box? Or does it need a separate power supply/splitter?
Hi Rusty,
Yep, you’ll need a PoE splitter, I can’t see anything that suggests PoE, that would likely push the cost up quite a bit as a transformer is usually needed for isolation.
This module can be powered from 5V, so something like these two products should be what you need:
