I am having trouble loading the media centre on my Pi 3. I have installed the disk image from the Openelec website. The first time I started the Pi3 it ran through the normal startup with the Openelec logo page and commands scrolling down the lefthand side but then it just goes to blackscreen. anyone else had this issue?..and solved it?
Assuming that you’re running with a fresh image of OpenELEC, there are a few things you can do to check that it’s been imaged correctly. Plug your SD card into your computer and open the command prompt (in the start menu, type “cmd” without quotes, and launch cmd.exe). In cmd, type in the following command (replace D with whatever the drive letter of your SD card is) and post a screen shot of the results here:
chkdsk /R D:
Then in cmd, type in (again, replace D with your drive), and post the screen shots:
dir D:
This will tell us if there is anything wrong with the basic OpenELEC image.
I tried a different sd card and it loaded first pop.I then re-formatted the supplied sd and burned a new openelec image and then it worked as well. It may have been human error on my part or a prob with my image writing software. Either way we are up and rolling nicely now.
thanks for the assistance.
