I’m having trouble with a LibreElec installation on a Raspberry Pi 4. The first issue is that for some reason when I reboot the Pi once it does its startup checks and shows the LibreElec screen it goes blank. If I remove the HDMI cable and re-insert it, it shows the Kodi interface. I have looked online for possible solutions, which mention editing the config.txt file. I have set this up multiple times and have never encountered this problem before.
On top of this there is no CEC connectivity as well as no audio. Could this all be related?’
I have solved an issue where it wasn’t loading the SQL database, by checking the “wait for network” option. Although, I now have a problem when it boots is has failure that says -
‘[FAILED] Failed to start Wait on Network.’
when I get a status on the kodi-waitonnetwork.service this is the result:
● kodi-waitonnetwork.service - Wait on network
Loaded: loaded (/usr/lib/systemd/system/kodi-waitonnetwork.service; disabled;
Active: failed (Result: exit-code) since Fri 2019-04-12 02:28:48 AEST; 1 year
Process: 352 ExecStartPre=/bin/sh -c echo "waiting on Network to come online .
Process: 357 ExecStart=/usr/sbin/connmand-wait-online --timeout=${WAIT_NETWORK
Main PID: 357 (code=exited, status=110)
Apr 12 02:28:38 LibreELEC-4K systemd[1]: Starting Wait on network...
Apr 12 02:28:48 LibreELEC-4K systemd[1]: kodi-waitonnetwork.service: Main proces
Apr 12 02:28:48 LibreELEC-4K systemd[1]: kodi-waitonnetwork.service: Failed with
Apr 12 02:28:48 LibreELEC-4K systemd[1]: Failed to start Wait on network.
I am now getting this error even if I uncheck the ‘wait on network’ option,
Thanks.
