I recently purchased a Pololu USB avr programmer v2.1 and am having some issues with getting it working. Using the SPI interface on two Arduino Mega clones I can bootload and then upload a sketch. However on two Nano clone boards I can only bootload them and uploading a sketch produces a error that they are not in sink and tries 10 times. Also how do I use the second header on the programmer the one with tx and rx pins.
Thanks for any help.
Pololu avr programmer with Arduino
Hi Rowan,
The second header on the Pololu USB AVR Programmer v2.1 is the USB to serial (We have a tutorial on how to use USB to Serial ).
Are you using the correct bootloader and configuration for the Nano board? Are you able to give the specific error and any codes it provides?
I believe I have followed the above tutorial. However uploading code using the USB to Serial does not work, I can upload code directly onto the same Mega not using the programmer however with the programmer I have had no success. I am trying to press the reset button at the correct time however I am not sure how important the timing is.
The error is as follows:
avrdude: Version 6.3-20171130
Copyright © 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright © 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\1.8.7\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM8
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: STK500
Hardware Version: 15
Firmware Version Master : 2.10
Topcard : Unknown
Vtarget : 0.2 V
SCK period : 8.7 us
Varef : 0.0 V
Oscillator : Off
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
An error occurred while uploading the sketch
Hi Rowan,
The timing of the Reset button is critical to getting the upload to work. I would play around with the timing and see if you can get it to work that way. Based on your error codes everything else seems to be working as expected.
Here is the full user guide for using this programmer. You may need to set it up with a utility prior to using it.
