Hi CE,
Am having an issue with a Pysense. Have upgraded FW, as per guides, all good and works initially as expected, COM port shows up etc. However after extended power down, overnight, the Pysense is no longer discoverable as a COM port, shows the libusbk device in the control panel, with ongoing connect and disconnect. Reloaded the firmware, success initially and then fails again after power down. No issue with the LoPy installed on Pysense, have moved this to a Exp Board 3.0 and works fine immediately. Your advice is appreciated. Thanks. Steve B.
