Rasp Pi 4 Colored Screen
Hi Guys
I put my Raspberry Pi 4 together last night and was in the process of installing Noobs. Everything was going fine and it was installing updates. I walked back into the room and it was powered down. When I powered on again I got the colored screen which I understand is fairly common. Can anyone assist with where I go from here to get it running.
Hey Jason,
It could be an issue with NOOBS being installed, if it persists, it is worthwhile doing a fresh install of Raspberry Pi OS on the SD card.
Is it staying on the coloured screen rather than moving further into the desktop?
If you remove the SD card and turn it on, are you still getting the bootloader screen?
Blayden
Hi Blayden
That worked. Thanks for your help
