I have a Raspberry Pi 4B 4GB that doesn’t appear to boot. I see nothing on the TV using HDMI and cannot see it on the network.
When I turn it on all I see is the red light power light on and the network lights on. Nothing else happens. No signal over HDMI, no green light, no heat from the CPU (even after a few minutes).
The odd thing about the network lights is that they are always on - not flashing. At the other end of the network cable, the network lights for the switch flash rapidly. A tcpdump from another Pi (v1B) connected to the same switch sees no traffic.
It did work when I first got it. I just gave it a short test run from an SD card that my Raspberry pi 3B was using. Now when I use this SD card or any SD card it doesn’t work.
Is it bricked/dead?
