No, the raspistill command still gives the “No data recevied from sensor.” error.
pi@raspberrypi:~ $ raspistill -v -o test.jpg
raspistill Camera App v1.3.11
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode ‘auto’, AWB Mode ‘auto’, Image Effect ‘none’
Flicker Avoid Mode ‘off’
Metering Mode ‘average’, Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera component done
Encoder component done
Starting component connection stage
Connecting camera preview port to video render.
Connecting camera stills port to encoder input port
Enabling encoder output port
Starting capture -1
mmal: No data received from sensor. Check all connections, including the Sunny one on the camera board
When I try the same test with the SUNNY disconnected I get a different error:
mmal: Cannot read camera info, keeping the defaults for OV5647
Opacity 255
mmal: mmal_vc_component_create: failed to create component ‘vc.ril.camera’ (1:ENOMEM)
mmal: mmal_component_create_core: could not create component ‘vc.ril.camera’ (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
So the raspberry can reach the camera, it just can’t take a photo.
I’ve updated the software too and am still getting the same error afterwards…
