Hi there - I have recently bought a raspberry pi 3+ board (second one i have purchased in quick succession). However on this one, there seems to be an issue with the camera port - in that it does not read images from the camera sensor.
I have the latest raspbian jesse image (installed from NOOBS).
I am using the official power supply,
Have enabled the camera connector in raspi-config.
But keep getting the following message (no data received from the sensor) when i issue the raspistill command: raspistill -v -o test.jpg
What leads me to think that its a faulty raspberry pi board is that when i use my other raspberry pi 3+ board with:
- Same microsd card image booted
- same powersupply
- same camera module (v2)
- when i issue the raspistill command, the image is received from the camera successfully and stored on the card.
I have even tried re-seating the camera cable on the board multiple times to no avail.
If it is a board problem - what are the procedures for sending it back for a replacement?
regards
Rennie
