Howdy,
I have played around with raspberry pi’s for a few years (this is my 5th my 1st was a Raspberry Pi Model A) but this is the first time I have tried to connect a camera (I have taken my time
). I’m working on a baby monitor with a v2 NoIR camera module on a RASPBERRY PI 3 MODEL B+ with the official Raspberry Pi power supply.
I am encountering the following error:
Camera control callback cmd=0x4f525245mmal: No data received from sensor. Check all connections, including the Sunny one on the camera board
When using raspistill -o Desktop/image.jpg
I have tried the following so far:
Changing the permissions on the Desktop folder to everyone
Rebooting the RPi several times.
Ensuring the RPi is up to date using - sudo apt-get update/upgrade and rpi-update.
Disconnecting and reconnecting the ribbon cable.
Reversing the direction of the cable.
Connecting and reconnecting the Sunny cable (when left disconnected I get a different error)
Enabling and disabling the camera using raspi-config (rebooting between changing of settings).
Re flashing the SD card with a new raspian buster image.
Using the following I get:
pi@raspberrypi-babymonitor:~ $ vcgencmd get_camera
supported=1 detected=1
I have also tried the camera unit on a different pi with a new image of raspian and get the identical issue.
I don’t have a second ribbon so I can’t try that at this stage.
Any advice will be well received and if I need to purchase another unit so be it
Tim
