Unlock the untapped power of your Raspberry Pi 5 with our state-of-the-art Active Cooler. Prevent thermal throttling, optimize CPU-intensive tasks, and unleash the full potential of your Pi 5. Elevate your Raspberry Pi experience to unparalleled performance today!
Yep! The Raspberry Pi AI HAT+ 26 TOPS will fit on a Pi 5 with an Active Cooler attached. This is the cooler used by Pi to test these AI HATs, so it should be the best one for the job!
Hi Support, is your Raspberry Pi 5 Active Cooler SKU: CE09791 compatible with the Raspberry Pi 4 Model B 1GB SKU: CE06423 I purchased from you previously. Cheers Bruce
Hi there, @Bruce188151, glad to see you back on the forums.
Unfortunately, the Pi 5 Active Cooler is not compatible with the Pi 4. The Pi 4 lacks both the support holes needed for holding the Active Cooler and Fan Controller connector to run it.
