Slim Case For Raspberry Pi 3 Model B+ (CE06233)
This is a placeholder topic for “Slim Case For Raspberry Pi 3 Model B+” comments.
If you’re looking for a slim and sleek case for your Raspberry Pi 3 Model B+ then look no further! The Slim Case for the Raspberry Pi 3 Model B+ allows full access to the GPIO pins, the camera and display ribbon connectors on the board and is also compatible with most HATs.
Can I install a fan on top of this case with a heat sink? I have Rpi 3B+
Hi Chirag,
Welcome!
I dont have the kits infront of me so the Core guys would have to confirm that everything fits but here’s my recommendation:
I imagine one of the smaller heatsink kits would definitely work such as these two:
As for a fan take a look at the Fan Shim and the FAN HAT.
And you’ll most likely need a header for additional clearance:
Hi Chirag,
Since you’ve got a Pi 3B+, you don’t need a ton of cooling unless you’re doing heavy work on the Pi all the time, I’d suggest just a small heatsink should do the trick:
If you did want a fan, as Liam said you’d likely need to space it out a bit with the stacking headers.
Did you have a particular product in mind you wanted us to test the fit of?
As said, I probably go for heatsinks as I am only running minimal services.
