USB Wi-Fi adapter for Raspberry Pi 4
I have built a trail camera using a Raspberry Pi 4, a Hi Quality camera with a 8-50 mm zoom lens, a 20 amp hour power block running MotionEyes. It connects using the built in W-Fi adapter. I purchased a SimpleCom NW392 USB Wireless N WiFi Adapter and a TP-Link 16 db Yagi external antenna to replace the internal Wi-Fi adapter. My question is, how do I configure the external USB Wi-Fi adapter? MotionEyes supplies instructions for configuring the internal Wi-Fi adapter, but not an external adapter.
The SimpleCom web site shows drivers for Linux v4.3.0.4 and Linux v4.2.2.
Thanks for your help,
Charles Hart
Hi Charles,
The first test I would do is use the command
 lsusb
in the Raspberry Pi terminal to see if the USB adapter is appearing as a connected device.
It’s not clear what Linux driver version will be the most suitable for the Raspberry Pi as it’s tied to the kernel version, I might need to do a bit more digging there and get back to you unless someone else is more familiar with Linux driver versions.
This is the result that I get when connected to MotionEyes using Putty…
[root@meye-7bb3e694 ~]# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 003: ID 0bda:818b
Bus 001 Device 002: ID 2109:3431
Bus 002 Device 001: ID 1d6b:0003
Charles
Not motioneyes OS, but on my RPi 4, I plugged in an USB wifi, did not have to configure anything. Were you able to connect to a network with the adapter connected? May be try disabling internal wifi and connect with the adapter?
simple lsusb gives me this:
lsusb
Bus 002 Device 002: ID 152d:0562 JMicron Technology Corp. / JMicron USA Technology Corp. JMS567 SATA 6Gb/s bridge
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0c45:7603 Microdia USB Keyboard
Bus 001 Device 003: ID 093a:2530 Pixart Imaging, Inc. Gaming Mouse
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Highlighted the connected devices in bold
If the Wifi adapter is connected and recognized, it should be shown as such.
See if this page will help with the set up
