Hi, after any advice - however suspect there is a hardware issue with the pi.
Brief summary - had the pi initially working fine connecting to home wifi after setting wpa_supplicant.conf in boot volume prior to starting. This had been fine for a couple of weeks. Then after a restart it failed to connect to the wifi.
After much troubleshooting trying to reconfigure a new wpa_supplicant.conf I ended up re-imaging the SD card.
I have subsequently re-imaged the SD card multiple times now. Always with the latest raspberrypi OS.
In troubleshooting things I have tried include:
- creating new wpa_supplicant.conf file on the SD card and restarting
- in a clean OS and connecting via SSH over USB - the raspi-config utility fails when setting wifi config with “no wifi interfaces found”
- I have copied /etc/network/interfaces and /etc/wpa_supplicant/wpa_supplicant.conf to match another working raspberrypi and to match various internet posts. This either has no effect or upon reboot stops my ability to ssh over USB onto the device (and it doesn’t assign an IP address).
Appreciate if anyone has some suggestions.
pi@raspberrypi:~ $ ifconfig
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 25 bytes 2392 (2.3 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 25 bytes 2392 (2.3 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 169.254.68.113 netmask 255.255.0.0 broadcast 169.254.255.255
inet6 fe80::54f3:ddd8:b2a2:f72d prefixlen 64 scopeid 0x20<link>
ether 86:46:bf:37:51:03 txqueuelen 1000 (Ethernet)
RX packets 133 bytes 28566 (27.8 KiB)
TX packets 113 bytes 13864 (13.5 KiB)
pi@raspberrypi:~ $ iwconfig
lo no wireless extensions.
usb0 no wireless extensions.```
